ich habe keine Idee, nur die Frage, was ich mir unter
vorstellen soll. Du gibst
sudo mount -t nfs 192.168.10.4:/A... /media/Qnap463/Und was sagt denn ein anschliessendes
mount
sudo mount -t nfs 192.168.10.4:/A... /media/Qnap463/Code: Alles auswählen
mountCode: Alles auswählen
# mount:
 INT ✘  32s 
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=16385308k,nr_inodes=4096327,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p2 on / type ext4 (rw,noatime)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=25265)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,size=16426300k,nr_inodes=1048576,inode64)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
/dev/nvme0n1p3 on /home type ext4 (rw,noatime)
/dev/nvme1n1p1 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3285256k,nr_inodes=821314,mode=700,uid=1000,gid=1001,inode64)
/dev/nvme1n1p4 on /run/media/joerg/Daten type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1001)
/dev/nvme1n1p3 on /run/media/joerg/606C8FAD6C8F7C92 type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1001)
Verspreche mir nicht viel davon, aber poste mal die Ausgabe vonLaGGGer hat geschrieben: Donnerstag 3. März 2022, 21:33 NAS immer über den Servernamen ansprechen, nicht über die IP
mountstats
nfsstatCode: Alles auswählen
systemctl status nfs-server.serviceCode: Alles auswählen
# mountstats
No NFS mount points were foundCode: Alles auswählen
# nfsstat
Error: No Client Stats (/proc/net/rpc/nfs: No such file or directory).
# systemctl status nfs-server.service
â—‹ nfs-server.service - NFS server and services
Loaded: loaded (/usr/lib/systemd/system/nfs-server.service; disabled; vendor preset: disabled)
Active: inactive (dead)
Client rpc stats:
calls retrans authrefrsh
29 0 29
Client nfs v4:
null read write commit open
1 3% 0 0% 0 0% 0 0% 0 0%
open_conf open_noat open_dgrd close setattr
0 0% 0 0% 0 0% 0 0% 0 0%
fsinfo renew setclntid confirm lock
3 10% 0 0% 0 0% 0 0% 0 0%
lockt locku access getattr lookup
0 0% 0 0% 1 3% 1 3% 2 6%
lookup_root remove rename link symlink
create pathconf statfs readlink readdir
0 0% 2 6% 0 0% 0 0% 0 0%
server_caps delegreturn getacl setacl fs_locations
4 13% 0 0% 0 0% 0 0% 9 31%
rel_lkowner secinfo fsid_present exchange_id create_session
0 0% 0 0% 0 0% 2 6% 1 3%
destroy_session sequence get_lease_time reclaim_comp layoutget
0 0% 0 0% 0 0% 1 3% 0 0%
getdevinfo layoutcommit layoutreturn secinfo_no test_stateid
free_stateid getdevicelist bind_conn_to_ses destroy_clientid seek
allocate deallocate layoutstats clone
0 0% 0 0% 0 0% 0 0%
hoffe ich mal, dass Du das aus Versehen auf dem Client losgelassen hast, Denn auf dem Server sollte nfs-server.service schon laufen und nicht "dead" sein.Mosconi hat geschrieben: Dienstag 8. März 2022, 09:39 nfs-server.service - NFS server and services
-o vers=3
nfsvers=3
