Code: Alles auswΓ€hlen
pactl list
Modul #0
Argument:
NutzungszΓ€hler: k. A.
Eigenschaften:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "12.2"
Modul #1
Argument:
Eigenschaften:
module.description = "Automatically restore the volume/mute/device state of streams"
Modul #2
Argument:
Eigenschaften:
module.description = "Automatically restore profile of cards"
Modul #3
Argument:
Eigenschaften:
module.description = "Augment the property sets of streams with additional static information"
Modul #4
Argument:
Eigenschaften:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Modul #5
Argument:
Eigenschaften:
module.description = "Detect available audio hardware and load matching drivers"
Modul #6
Argument: device_id="0" name="pci-0000_00_07.0" card_name="alsa_card.pci-0000_00_07.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1"
NutzungszΓ€hler: 0
Eigenschaften:
module.description = "ALSA Card"
Modul #7
Argument:
Eigenschaften:
module.author = "FrΓ©dΓ©ric Dalleau, Pali RohΓ‘r"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Modul #8
Argument:
Eigenschaften:
module.author = "JoΓ£o Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Modul #9
Argument:
Eigenschaften:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Modul #10
Argument:
Eigenschaften:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Modul #11
Argument:
Eigenschaften:
module.description = "ESOUND protocol (UNIX sockets)"
Modul #12
Argument:
Eigenschaften:
module.description = "Native protocol (UNIX sockets)"
Modul #13
Argument:
Eigenschaften:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Modul #14
Argument:
Eigenschaften:
module.description = "Automatically restore the default sink and source"
Modul #15
Argument:
Eigenschaften:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Modul #16
Argument:
Eigenschaften:
module.author = "Colin Guthrie"
module.description = "HΓ€lt stets ein Ziel geladen, selbst wenn dies ein Null-Ziel ist"
Modul #17
Argument:
Eigenschaften:
module.description = "Automatically set device of streams based on intended roles of devices"
Modul #18
Argument:
Eigenschaften:
module.description = "When a sink/source is idle for too long, suspend it"
Modul #19
Argument:
Eigenschaften:
module.description = "Create a client for each ConsoleKit session of this user"
Modul #20
Argument:
Eigenschaften:
module.description = "Create a client for each login session of this user"
Modul #21
Argument:
Eigenschaften:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Modul #22
Argument:
Eigenschaften:
module.description = "Mute & cork streams with certain roles while others exist"
Modul #23
Argument:
Eigenschaften:
module.description = "Detect when various filters are desirable"
Modul #24
Argument:
Eigenschaften:
module.description = "Load filter sinks automatically when needed"
Modul #25
Argument: display=:0.0
Eigenschaften:
module.description = "X11 credential publisher"
Modul #26
Argument: display=:0.0 session_manager=local/manjaro-pc:@/tmp/.ICE-unix/601,unix/manjaro-pc:/tmp/.ICE-unix/601
Eigenschaften:
module.description = "X11 session management"
Ziel #0
Status: SUSPENDED
Beschreibung: Internes Audio Analog Stereo
Treiber: module-alsa-card.c
Abtastwert-Angabe: s16le 2ch 44100Hz
Kanalzuordnung: front-left,front-right
Besitzer-Modul: 6
Stumm: nein
LautstΓ€rke: front-left: 32897 / 50%, front-right: 32897 / 50%
Verteilung 0,00
Basis-LautstΓ€rke: 65536 / 100%
Quellen-Monitor: alsa_output.pci-0000_00_07.0.analog-stereo.monitor
Latenz: 0 usec, eingestellt 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL LATENCY
Eigenschaften:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC888 Analog"
alsa.id = "ALC888 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xfe020000 irq 21"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:00:07.0"
sysfs.path = "/devices/pci0000:00/0000:00:07.0/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0774"
device.product.name = "MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio"
device.form_factor = "internal"
device.string = "front:0"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Internes Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC888"
alsa.components = "HDA:10ec0888,10250157,00100202"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-lineout: Line-Ausgang (priority: 9900, not available)
Aktiver Port: analog-output-lineout
Formate:
pcm
Quelle #0
Status: SUSPENDED
Beschreibung: Monitor of Internes Audio Analog Stereo
Besitzer-Modul: 6
Stumm: nein
LautstΓ€rke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
Verteilung 0,00
Basis-LautstΓ€rke: 65536 / 100% / 0,00 dB
Ziel-Monitor: alsa_output.pci-0000_00_07.0.analog-stereo
Flags: DECIBEL_VOLUME LATENCY
Eigenschaften:
device.description = "Monitor of Internes Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formate:
pcm
Quelle #1
Status: SUSPENDED
Besitzer-Modul: 6
Stumm: nein
Verteilung 0,00
Ziel-Monitor: k. A.
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Eigenschaften:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
Ports:
analog-input-front-mic: Vorderes Mikrofon (priority: 8500)
analog-input-rear-mic: RΓΌckwΓ€rtiges Mikrofon (priority: 8200, not available)
Aktiver Port: analog-input-front-mic
Formate:
pcm
Client #0
Treiber: module-systemd-login.c
Owner-Modul: 20
Eigenschaften:
application.name = "Login Session 1"
systemd-login.session = "1"
Client #1
Treiber: protocol-native.c
Owner-Modul: 12
Eigenschaften:
application.name = "xfwm4"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "32"
window.x11.display = ":0"
window.x11.screen = "0"
application.process.id = "663"
application.process.user = "manjaro"
application.process.host = "manjaro-pc"
application.process.binary = "xfwm4"
application.language = "de_DE.utf8"
application.process.machine_id = "8173ad2d200f4caf8e8ce67b8f0a4b8a"
application.process.session_id = "1"
Client #2
Owner-Modul: 12
Eigenschaften:
application.name = "xfce4-pulseaudio-plugin"
application.version = "0.4.2"
application.id = "org.xfce.pulseaudio-plugin"
application.icon_name = "multimedia-volume-control"
application.process.id = "693"
application.process.binary = "wrapper-2.0"
Client #5
Treiber: module-x11-xsmp.c
Owner-Modul: 26
Eigenschaften:
application.name = "XSMP Session on xfce4-session as 26ef442b6-b984-435b-93a4-e72408476d2a"
xsmp.vendor = "xfce4-session"
xsmp.client.id = "26ef442b6-b984-435b-93a4-e72408476d2a"
Client #6
Owner-Modul: 12
Eigenschaften:
application.name = "pactl"
application.process.id = "1285"
application.process.binary = "pactl"
window.x11.display = ":0.0"
Karte #0
Owner-Modul: 6
Eigenschaften:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Internes Audio"
Profile:
input:analog-stereo: Analog Stereo-Eingabe (Ziele: 0, Quellen: 1, PrioritΓ€t: 65, verfΓΌgbar: ja)
output:analog-stereo: Analog Stereo-Ausgabe (Ziele: 1, Quellen: 0, PrioritΓ€t: 6500, verfΓΌgbar: nein)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (Ziele: 1, Quellen: 1, PrioritΓ€t: 6565, verfΓΌgbar: ja)
off: Aus (Ziele: 0, Quellen: 0, PrioritΓ€t: 0, verfΓΌgbar: ja)
Aktives Profil: output:analog-stereo+input:analog-stereo
Ports:
analog-input-front-mic: Vorderes Mikrofon (priority: 8500, latency offset: 0 usec)
Eigenschaften:
device.icon_name = "audio-input-microphone"
Teil der/des Profil(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-rear-mic: RΓΌckwΓ€rtiges Mikrofon (priority: 8200, latency offset: 0 usec, not available)
Eigenschaften:
analog-output-lineout: Line-Ausgang (priority: 9900, latency offset: 0 usec, not available)
Teil der/des Profil(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
